No answer for DNE errors?
Sep 4th, 2008
I've read through most of the posts involving Deterministic Network Enhancer problems but there is very little help.
I work for a large company where we frequently need to reinstall VPN and run into DNE errors. The latest... "Error: DNE installation requires a reboot first. Please run this install again after restarting the computer." But rebooting the computer changes nothing.
sadbulali Wed, 09/10/2008 - 08:43
  • Bronze, 100 points or more
Just by trial and error, I found that you have to make sure the pc has "Deterministic Netowrks" source files exist in "C:\Program Files\Common Files\Deterministic Networks". Just copy from a different PC if they are not there. If this didn't fix the problem, you would need to add deterministic network service to your via network properties and that should do it.
kosborne1 Wed, 09/10/2008 - 08:47
I tried that a while back and it did not work. But this did...
Rename Windows\System32\dneinobj.dll &
System32\Drivers\dne200.sys
Reboot and try the install again.
