Problem with STP
Sep 4th, 2008
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
We are have a problem with Spane tree Protocol. In this router appear the message ininterrupet:
Sep 1 23:24:07.400 GMT-3: %SPANTREE-SP-6-PORT_STATE: Port Gi2/5 instance 10 moving from forwarding to blocking
Sep 1 23:24:07.400 GMT-3: %SPANTREE-SP-6-PORT_STATE: Port Gi2/5 instance 11 moving from forwarding to blocking
Sep 1 23:24:07.400 GMT-3: %SPANTREE-SP-6-PORT_STATE: Port Gi2/5 instance 12 moving from forwarding to blocking
Sep 1 23:24:07.400 GMT-3: %SPANTREE-SP-6-PORT_STATE: Port Gi2/5 instance 13 moving from forwarding to blocking
Sep 1 23:24:07.624 GMT-3: %SPANTREE-SP-6-PORT_STATE: Port Gi2/5 instance 10 moving from blocking to forwarding
Sep 1 23:24:07.624 GMT-3: %SPANTREE-SP-6-PORT_STATE: Port Gi2/5 instance 11 moving from blocking to forwarding
Sep 1 23:24:07.624 GMT-3: %SPANTREE-SP-6-PORT_STATE: Port Gi2/5 instance 12 moving from blocking to forwarding
Sep 1 23:24:07.624 GMT-3: %SPANTREE-SP-6-PORT_STATE: Port Gi2/5 instance 13 moving from blocking to forwarding
But, I don't know where start the investigation. Somebody have any Idea?
Thank You,
Wilson
simontibbitts Thu, 09/04/2008 - 12:52
  • Silver, 250 points or more
Hi Wilson.
I'd be interested on seeing the STP statistics for that port and the configuration.
Collect the command below twice with a few seconds inbetween each command (Where x is your VLAN)
show spanning-tree vlan x interface Gi2/5 detail
The last set of counters show the received BPDU statistics, work out between the two commands how many BPDUs you received in those few seconds. If the number increased a bit then this might be the problem.
- Simon
wilsonsant Tue, 09/09/2008 - 10:15
Hi Simon,
I did the tests and there are incresed any bit in the interval few minutes.
Thank You,
Wilson
simontibbitts Tue, 09/09/2008 - 10:41
Sorry Wilson, I don't understand,
Did the BPDU counter increase?
or did the BPDU counter NOT increase?
Simon
wilsonsant Tue, 09/09/2008 - 10:43
Hi Simon,
I did the test bellow:
ALD-CE-ROTNGN-OI-01#SH SPanning-tree vlan 701 interface giga2/5 detail0 interface giga2/5 detail2 interface giga2/5 detail
Port 133 (GigabitEthernet2/5) of MST13 is designated forwarding
Port path cost 20000, Port priority 128, Port Identifier 128.133.
Designated root has priority 8205, address 0016.9c6d.a140
Designated bridge has priority 8205, address 0016.9c6d.a140
Designated port id is 128.133, designated path cost 0
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 67283
Link type is point-to-point by default, Internal
BPDU: sent 134142, received 404290
ALD-CE-ROTNGN-OI-01#SH SPanning-tree vlan 702 interface giga2/5 detail
Number of transitions to forwarding state: 67285
BPDU: sent 134146, received 404304
Thank You,
Wilson
simontibbitts Tue, 09/09/2008 - 10:52
Thanks Wilson.
This is your problem, you need to investigate the switch attached to this port to work out why it is sending so many BPDUs, To stop the problem straight away you can just filter BPDUs on that port. 'spanning-tree bpdufilter enable'
Of course, however make sure it does not affect your STP tree. If this port should not be connecting to another switch then its not a problem.
Check out this link for a description of the situation. Its under the heading 'Attack 2: DoS Using a Flood of Config BPDUs' Its a known DoS attack.
http://www.ciscopress.com/articles/article.asp?p=1016582&seqNum=2
Simon
Francois Tallet Tue, 09/09/2008 - 15:05
  • Gold, 750 points or more
Please, don't filter BPDUs, that would essentially mean disabling STP on this interface and could result in permanent loop if you have redundancy.
In MST, it is usual to have a port both sending and receiving BPDUs, as it can have different roles on different instances.
However I agree that it is not normal that this port receives that many BPDUs. What is connected on the other side? BPDUs are normally rate limited. The standard allows for a short burst then you should not get more than one BPDU per second (Cisco is a little bit more aggressive by default and allow something like 7 BPDUs per second in MST mode I think, it can be configured).
I would recommend you try to clarify what's happening on the other side first.
Francois
wilsonsant Wed, 09/10/2008 - 11:58
Hi François,
There are equipment of another vendors in this solution. I asked for my customer the Topology of Network, but, He not still send for me. I Believe that it's impossible solve this problem without the Topology of Network, wright?
Thank You,
Wilson
Francois Tallet Wed, 09/10/2008 - 12:05
Hi Wilson,
It's more than the topology you need here I'm afraid. It's true that it's difficult to troubleshoot STP over different administrative entities. In a provider/customer environment, many provider choose to tunnel their customer's STP instead of peering with it.
Now, if you are absolutely sure on your side that this customer is not connected redundantly to your network, you can indeed filter BPDUs and de facto disable STP. I guess that if you are peering, it's because you have some form of redundancy. Your only choice is thus to have the customer cooperate in the troubleshooting. Hopefully, because their interface is flapping on your side, they should have some interest in doing so too;-)
Honestly, I have no clue of what the problem can be with this information. You should receive a "reasonable" rate of BPDUs on your interface. It seems that it far excessive (but I'm not sure, as I don't have an timing information). The MST information is not consistent, and because of that, the port has its state flapping. Sorry, that's as much as I can tell:-(
Francois
