Command for version over ASA
Sep 4th, 2008
Hi there, please i have to look the software version of my asa and when i use show version and then i look the software version it is for example
7.2(4). Ok. Now, it seems the we have same vulneravility over same asa software version. The vulnerability note is Document ID: 107475. It seems that the afected release for example is 7.2 and the first fixed release is 7.2(4)2. What command i have to apply to see my real software version. Thanks.
King Regards.
Elias Vucinovich.
Overall Rating: 5 (1 ratings)
srue Thu, 09/04/2008 - 19:44
if the output of show version is 7.2(4), then the real version is 7.2(4). 7.2(4)2 is an interim release that you can download. usually its recommended that you only download them if you are affected by a particular bug that a given interim release fixes. they are fully supported by TAC.
at the top of the asa software download page, click "ASA Interim Releases" to find these versions.
