Rob Huffman Thu, 09/04/2008 - 16:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jose,
If you don't want to use Extension Mobility then you could use Forced Authorization Codes (FAC);
The Forced Authorization Codes (FAC) feature, which allows you to regulate the types of calls that certain users can place, forces the user to enter a valid authorization code on the phone before the call completes.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed710.html
Configuring Forced Authorization Codes
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3af7.html#wp1078125
Hope this helps!
Rob
eljose_lol Fri, 09/05/2008 - 06:07
hi bob
thx for reply, my client needs some config or app that do a "lock" of the phone, a feature found in PBX old phones.
thx.
