TACACS enable
To all R&S expert,
I have a customer which wants their TACACS server to authenticate for both 'lgoin' as well as 'enable'. However, doesn't matter what they do, they get prompt for the username and password twice. However, they want to be prompt for both username + password once during 'login', but when they press enable, they only want the password to be prompt, but not the username again.
Currently they have the following config on their Cat 6513
aaa authentication password-prompt "Backup-password: "
aaa authentication username-prompt "Backup-username: "
aaa authentication login default group tacacs_group local
aaa authentication enable default group tacacs_group enable
And they currently see the following when login and enable
!!! NO UNAUTHORIZED ACCESS !!!
Access to this device or the attached networks
without explicit written permission is prohibited
and will be prosecuted.
Username: ibm
Password:
MPELZ21CS01>en
User Access Verification
Username: ibm
Password:
MPELZ21CS01#
I have spent a great amount of time on this already but couldn't figured out why. Would appreciated anyone's help.
Cheers,
Hunt
srue Thu, 09/04/2008 - 18:59
  • Blue, 1500 points or more
have you looked at the settings on their ACS server?
what version of software on the switch and tacacs server?
Calin Chiorean Thu, 09/04/2008 - 23:30
  • Silver, 250 points or more
Hi!
I understand that you want something like this:
---didi is the name of the c6500 where I'm doing ssh-----
ssh didi -l john
[email protected]'s password: ******
didi>ena
Password: ******
didi#
Then please try the sample config below:
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
tacacs-server host xxx.xxx.xxx.xxx
tacacs-server directed-request
tacacs-server key *******
line vty 0 4
exec-timeout 30 0
logging synchronous
transport preferred ssh
transport input ssh
The rest of the config is done on ACS server.
If you have the possibility try it and tell me if it is working!
Cheers,
Calin
Calin Chiorean Thu, 09/04/2008 - 23:37
Btw, if you want that the user to be authenticated directly to enable (privilege 15)
use the additional line below under "aaa new-model"
aaa authorization exec default group tacacs+ if-authenticated
Good luck!
Calin
