LMS 2.6 Cannot configure port-security
Sep 4th, 2008
hi, I'm running LMS 2.6 and IOS ver 12.2 (45) SG on a 4506.
I can't go into the port-security page to change settings or delete sticky mac address.
Getting a error say I've enabled dot1x, which I didn't.
we are using cisco view V6.1.5 module with Cat 4000 (6.0) & Cat 4000 ISO (13.0) package.
Thks
Anonymous (not verified) Wed, 09/10/2008 - 06:28
You may ensure whether the IOS version you are running is having problem with “cpsSecureMacAddress”. if cpsSecureMacAddress does not reply with the correct answer, the port secure will not work.
The following URL may help you:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/ps7005/prod_white_paper0900aecd805f1a93.html
tanywt Wed, 09/10/2008 - 16:10
Hi, but how do I check what is the reply for cpsSecureMacAddress?
