ACL port control through PAT
Sep 4th, 2008
I am trying to permit/deny access to certain ports from outside to inside ip addresses through PAT controlled 1841 router. Any help would be appreciated. The goal is to assign inside PC's with an ip address through login scripts then permit or deny website access to that PC.
spremkumar Thu, 09/04/2008 - 21:36
You can configure the same soemthing like this :
ip nat inside source static tcp 25 25
ip nat inside source static { tcp | udp }
This might help you to achieve the goal.
triumph1200 Fri, 09/05/2008 - 07:19
I should have been more specific. I need to permit/deny multiple websites to multiple PC's so Static NAT will not work.
