LMS 2.6 ios upgrade and flash files
Sep 4th, 2008
Running LMS 2.6 and RME 4.0.6
I have a need to upgrade the IOS on our routers via ciscoworks, however when the IOS is deployed the flash on the target router has its files greater than 1MB size deleted.
I need to keep some .wav files for messages-on-hold on the flash. These files are about 4MB in size and exist prior to any upgrade of the ios on the target router.
I dont mind if the previous version of the IOS is deleted - say by telling ciscoworks it is ok to delete files greater than 5MB if flash space is needed.
Is there a setting where I can tell the software distribution to delete files over 5 MB instead of the default 1 MB?
Cameron
Joe Clarke Fri, 09/05/2008 - 02:00
Unfortunately, this is not yet possible. RME will simply call "erase flash" or "format flash" prior to copying the new image. Any other require files will have to be restored once the job completes.
