OSI Layers working in both directions?
Sep 4th, 2008
Hello friends,
this question is with regard to the OSI model...
as far i remember, 7 layers of OSI model work in either direction i.e from top to bottom (from layer-7 to layer-1) and from bottom to top (from layer-1 to layer-7).
In the ICND-1 official module, it talks about the Encapsulation and De-Encapsulation processes. Accoring to the Encapsulation process, when sender sends the data,it is encapsulated and passed from Application layer to Physical Layer.Now when receiver receives this data,it gets De-Encapsulated and passes from Physical layer to Application Layer. Therefore in this whole process, data was passed from Layer-7 to Layer-1(Encapsulation), and then was later passed from Layer-1 to Layer-7 (De-Encapsulation).
The confusion starts when Cisco, soon after this, talks about the 'Peer to Peer Communication'.
My question is that the same 'Encapsulation and De-Encapsulation' process is followed in the P2P communication? and OSI layers always work in both directions?
Calin Chiorean Thu, 09/04/2008 - 23:59
Hi there!
It has been a while since I got CCNA, but for me P2P communication is describing the way that 2 peers communicate (as an example P2P is opposite to hub-and-spoke). Of course that encapsulation and de-encapsulation of the packets take place no matter if the communication in P2P or another type (eg. hub-and-spooke).
For me OSI layer and type of communication are 2 different things. L1-L7 or L7-L1 take place no matter of the method of communication.
Please tell me if you need more info.
ahmednaas Fri, 09/05/2008 - 04:09
P2P is a form network communications and therefore follows the OSI model. Please note that:
- The OSI model is an idealized model and that the TCP/IP stack doesn't follow the OSI model to the letter since it has less than seven layers and some protocols are not confined to a single OSI layer.
- P2P is an alternative to the client-server model of networking. The [en/de]-encapsulation you refer to is applicable in both cases.
Ahmed Naas
