ME 3400 stack
Sep 5th, 2008
i have 2 simple questions :)
Is it possible to stack the ME3400 switch?
If yes, what cable do i need to use in this stack.
If no, is it planned for future?
I really appreciate your help (replies) on this.
Regards.
Overall Rating: 5 (1 ratings)
ulapuschkin Fri, 09/05/2008 - 06:00
you can use the ME3400 in in a cascaded configuration.
please see:
http://www.cisco.com/en/US/docs/switches/metro/me3400/hardware/installation/guide/3400hig.pdf
The Cisco ME switch supports the SFP module patch cable, a 0.5-meter, copper, passive cable with SFP module connectors at each end. The patch cable connects two Cisco ME switches in a cascaded configuration.
On the Cisco ME-3400-24FS-A switch, only the Gigabit Ethernet uplink ports support the SFP module patch cable.
You can order the SFP module patch cable (part number CAB-SFP-50CM=).
regards
Udo
