Utilzation on Cisco 6513 switch
Answered Question
Sep 5th, 2008
Had a partner doing backups acoss the network between a 3750 and 6513 core switch ove a gigabit backbone. it looks like this caused issues with other connections through the 6513. It looks like the gigabit port was going up to 10MB which does not seem that high. I would see time outs on pings when we stopped the backups it looks like the problem may have gone away. i have been looking for commands to use on the 6513 to see utilzation for the cpu and ports to troubleshoot this.
Correct Answer by satish_zanjurne about 8 years 5 months ago
1.For CPu utilization
"show process cpu | exclude 0.00"
2.For interface regular commands like
"show interface ***"
Look for load,input rate,output rate
Clear the counters , before starting monitoring the interface.
3.Other option is Netflow
HTH..rate if helpful..
Overall Rating: 4.3 (3 ratings)
glen.grant Fri, 09/05/2008 - 04:53
Use show proc cpu sort and it will sort from highest to lowest the functions that are using the cpu. In a 6513 most traffic should never hit the cpu , if it is then you have a problem .
Correct Answer
satish_zanjurne Fri, 09/05/2008 - 01:27
