VPN
Cisco CyberSecurity
Labels
Hello,I want to set up a IPSec IKEv2 VPN to a central ASA. On my side we have a cisco 897.First I tried a crypto map configuration. Didn't work because the IKEv2 SA goes UP and immediately goes DOWN with the error message "IKEv2:(SESSION ID = 1,SA ID...
rolfd by Level 1
  • 528 Views
  • 19 replies
So something weird was happening when we were setting up a VPN connection yesterday (tunnel is up now and passing traffic). Here is a diagram of our topology:(10.26.0.0/16)--ASA-1-------------ASA-2--(192.168.1.0)So our tunnel didn't come up right awa...
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 1197 Views
  • 36 replies
Afternoon All,I am currently working on a Site-2-Site VPN at home I have connected a cable between both Outside Interfaces. It's been a while since I have done this on an ASA5505. I have this little voice telling me there is an issue with the differe...
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 910 Views
  • 15 replies
Hi, after upgrading the ASA SHIMO VPN app stopped working. I noticed that openconnect stopps working as well and to fix this issue for openconnect I just added --useragent=AnyConnect and it started to work. I tried to add this to shimo in expert mode...
I get the regular connect and disconnect messages ie the 7220xx messages but I tested several bad password attempts and they do not get logged. is there a way to log this?Would be interested in creating an EEM that would alert on a significant amount...
