QSIG MGCP INTREGATION with MD110
Sep 5th, 2008
Hi everybody, i have done a qsig MGCP integration with an MD110.
Everything works fine, but my problem begins when other PBX that are integrated too with MD110 don't arrive my calls (an ALCATEL with a qsig trunk against the ericsson MD110).
I trace the qsig q931 of my voicegateway.
Can anybody help me about.
In the attachmen you can see a call originated in my CCM 6.1 and the destination called is an extension through this alcatel-PBX.
An puts me the next statement:
*Sep 5 11:05:41.159: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0
x8033
Cause i = 0x81E5 - Message not compatible with call state
The calls between the CCM 6.1 and the MD110 works right!!
Thanks in advance
slongewa Wed, 09/10/2008 - 14:29
What version of the MD110 software are you running? What does the route data look like for the trunk going to the CCM and the Alcatel look like? (I believe the command is RODAP; if you are in command line mode on the Ericsson, but can't remember for sure.)
Thx,
Steve
