Traffic Shaping
Sep 5th, 2008
  • Gold, 750 points or more
Under sh traffic-shape fastEthernet 0/0, the output is Target rate = 640000 (bps), Sustains bits/int = 40000 (bits), Internal 62ms and increment 5000 (bytes).
From my understand the total bandwidth allowed on the physical interface is 640Kbps. The sustains bits is the Burst committed which means what the router is only allowing the maximum traffic to be sent through the interface is 40000 bits every 62ms (Time committed). Can someone advise pls. I sometime confuse myself with the traffic shaping equation.
Francisco
Overall Rating: 4 (1 ratings)
Marwan ALshawi Fri, 09/05/2008 - 05:01
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
try this show command will give u better details
show policy-map interface
for example
R3#show policy-map
Policy Map shape-all
Class class-default
Traffic Shaping
Average Rate Traffic Shaping
CIR 64000 (bps) Max. Buffers Limit 1000 (Packets)
R3#show policy-map interface s0/0.1
Serial0/0.1
Service-policy output: shape-all
Class-map: class-default (match-any)
7718 packets, 837830 bytes
30 second offered rate 69000 bps, drop rate 5000 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
64000/64000 2000 8000 8000 125 1000
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 56 6393 692696 6335 684964 yes
if helpful Rate
