Spanning Tree BPDU Guard Question
Sep 5th, 2008
Once you have enabled spanning tree bpdu guard on a Cisco switch, how do you disable it? I researched the command and there doesn't seem to be a no spanning-tree portfast bpduguard.
satish_zanjurne Fri, 09/05/2008 - 06:23
  • Silver, 250 points or more
"no spanning-tree bpduguard"
"spanning-tree bpduguard disable"
Globally you can use
"no spanning-tree portfast bpduguard default"
HTH..rate if helpful...
satish_zanjurne Fri, 09/05/2008 - 06:29
Globally for all interfaces "spanning-tree portfast bpduguard default" will enable for all interfaces...
