Danilo Dy Fri, 09/05/2008 - 09:53
There are many definitions for a virtual router, depends on the situation.
One of them is an application that simulates a router. i.e. dynamips http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
Another one is a protocol that advertise a "virtual router" (an abstract representation of master and backup routers acting as a group). Virtual Router Redundancy Protocol (VRRP) http://en.wikipedia.org/wiki/Virtual_router_redundancy_protocol
Giuseppe Larosa Fri, 09/05/2008 - 13:27
on high end routers like CRS you can logically partition the chassis and the linecards in so called virtual routers that will have separate management, interfaces, a share of resources.
Other vendors call virtual router the equivalent of an MPLS VRF
Hope to help
Giuseppe
