Moving from CME/CUE model to CUCM/CUE model
Answered Question
Sep 5th, 2008
  • Silver, 250 points or more
Hello friends:
We are moving from CME/CUE model to CUCM/CUE model. While we are doing this, is there any problem of loosing any data like voicemails or AA features?
Also how does the licenses get converted.
Thanks for any help
Correct Answer by Chris Deren about 8 years 8 months ago
You should not loose any functionallity, you can download the CM license for CUE instead of CME and apply it. Obviously you will also have to create the CTI integration on both sides.
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Fri, 09/05/2008 - 08:49
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
