Need help in configuring NAT on this Friday Afternoon...
Answered Question
Sep 5th, 2008
ok, my brain is no longuer functioning right...
Need to nat an external IP to an internal IP (or port forward of somekind).
Example:
External IP on E1/1 68.10.10.10 port 25
to
Internal IP on F0/1 10.10.10.15 port 25
How could I do this?
This is on a 3600 router, I know it's not a firewall but can this still be done? if so, How?
Correct Answer by jonesm111 about 8 years 4 months ago
You must also enable NAT to happen on the interfaces that it passes through as well.
like; ip nat inside (allow inbound NAT)
Here is an example..
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_nat.html
Please rate if it helps...
--Mike
Overall Rating: 5 (1 ratings)
Collin Clark Fri, 09/05/2008 - 10:28
ip nat inside source static tcp 192.168.0.1 80 interface serial0 80
Hope that helps.
pipsadmin Fri, 09/05/2008 - 10:36
so this would work for inbound traffic comming from the outside being routed to the internal device?
