Can MARS report on its self?
Answered Question
Sep 5th, 2008
I have a MARS-100 and was wondering if it can do self reporting. Such as notify me if the disk are full or if there was a unsucessful login attempt.
Correct Answer by Farrukh Haroon about 8 years 9 months ago
Did you check the following portion of the MARS GUI?
Reports >> System: CS-MARS Issue (Rule Group)
You will find already created reports for these tasks.
Farrukh
Overall Rating: 5 (2 ratings)
Correct Answer
Farrukh Haroon Sat, 09/06/2008 - 04:31
  • Red, 2250 points or more
Farrukh
mhellman Mon, 09/08/2008 - 04:55
  • Blue, 1500 points or more
Go to management->event management. enter "MARS" into the description and click search. This will list the individual MARS specific events. This does NOT include all the self monitoring that is done by MARS. There is some amount of monitoring that occurs for which there is no GUI interface. I have seen NFS failures and RAID failures generate emails but nothing in the GUI for examples. The login attempts you can get at. You can map those back to inspection rules by copying the rule group and then doing a search in Rules->inspection rules.
