100 mg connection
Sep 5th, 2008
We are in the process of ordering a 100 mg metro connection from point a to location b and C. The link will be carrying data to point b and voice and data to point c. How can we break up the link like 50/50 to both sites?
cisco_lad2004 Fri, 09/05/2008 - 12:56
  • Gold, 750 points or more
Use QOS to reserve bandwidth for each traffic type.
1st you classify the traffic then you use policy map which you attach to the interface.
Sam
Joseph W. Doherty Fri, 09/05/2008 - 16:28
Spliting 50/50 may not be optimal. What's the bandwidth at both locations b and c? If both also have 100 Mbps, set the interface to 100 Mbps, and using CBWFQ, place VoIP into LLQ, everything else FQ. Also if both b and c have 100 Mbps, you'll need to consider their traffic to location a, especially with VoIP in the mix.
Will the metro provider provide any QoS support? If not, site c can be similar to site a but site b will need to be shaped to reserve bandwidth for c to a VoIP.
