BAT insertion of lines w/ voicemail checked
Sep 5th, 2008
I have to insert a bunch of 7960 phones into CCM 6 where some of the lines need to go to VM and others not.
The BAT Excel doc doesn't have the voicemail checkbox option. Would putting in the VM Pilot # in the destination field accomplish the same thing?
Or would this need to be edited manually after insertion?
Overall Rating: 5 (1 ratings)
Robert Milanovich Fri, 09/05/2008 - 13:16
I normally would, however, in this case there are too many combinations of forward to VM, fwd to DN, and do nothing. I would wind up with probably 50 templates for the 250 phone I need to import.
Rob Huffman Sun, 09/07/2008 - 08:24
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rob,
This idea should work perfectly. Set the Template for the Forwarding that most of the phones will use. Then set the values for the other phones in the .csv as you suggested (this can be the VM Pilot # if you wish). The settings that are entered directly in the .csv will override the Template config. Here is a similar example;
Overriding Template Values Example
If you want most of the phones in the bulk transaction to be redirected to a
voice-messaging system, you can set the Call Forward Busy (CFB) and Call
Forward No Answer (CFNA) fields to the voice-messaging number. However, if
a few phones in the bulk transaction need to be redirected to a secretary instead
of to a voice messaging system, you can specify the secretary's directory number
in the Call CFB and CFNA fields in the CSV data file. Most of the phones will
use the CFB and CFNA values from the BAT phone template, but certain phones
will use the secretary's directory number as specified in the CSV data file.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_0_1_cucm401/bat_ovr.pdf
Hope this helps!
Rob
vivian.le Tue, 01/12/2010 - 18:32
In case anyone is still interested...
It is actually possible to BAT this field.  The attribute to have the vm box checked is "Forward Busy Internal Voice Mail 1" and "Forward Busy External Voice Mail 1" and so on and so forth for No Answer and the rest.  Marking the field "t" will check the box.  My template started with all of the boxes unchecked so my rows either contained the letter "t" or was blank.  But an important key was that in order to have it import correctly, the MAC address field must begin with SEPXXXXXXXXXXXX.
You'll find that if you attempt to validate the file, it will fail, but if you proceed with inserting phones with specific fields, it will import successfully.
ian.ryder Mon, 09/12/2011 - 00:51
Hi - I had this working in CUCM v6.1.3, I have upgrade to v7.1.5 and now import fails with an error stating the 'Forward xxxx Voice Mail 1' is not a supported field.
Also to note - if I do a BAT export of all details, these fields still exist, I am trying to do the import using the specific details options.
Any ideas anyone?
MRCobb Fri, 07/06/2012 - 14:25
I have also found this to be a pain when importing phones.  Having been through this a couple of times in large cutovers, I started buildout out phones into two different partitions.  Once is called BAT and the other BAT-VM which do not belong to any CSS (Allows for the build of the phones without making them live)  Once the phones are imported I run an update lines job to change the lines that are in the BAT-VM partition to have a VM profile as well as the check boxes checked off.  When I decide that the phones are ready for production, I then run another job to change the partition to whatever partition the DNs are in for production.
I know that this post is old but I was trying to find a way to import voicemail profiles and check boxes and could not find anything that seemed to makie life easy.  This is my workaround.  I hope this is found useful.....
