4.2 translation profile routed out pri
Sep 5th, 2008
I have a xlation profile which changes inbound did's from 0XXX to 1XXX. currently,these are cisco phones. I need to then have these forwarded out an attached QSIG PRI to a dialogix pbx to desktop OCS clients. Not sure how to forward out qsig pri, since endpoints will no longer be cisco. any help is appreciated.
Overall Rating: 4 (1 ratings)
Jaime Valencia Fri, 09/05/2008 - 13:28
just configure a route pattern to match 1XXX and route them to the QSIG PRI you have configured, once you delete the phones when the xlation pattern takes effect the only match will be the route pattern and will make calls go to the PBX or whatever you have at the other end
if this helps, please rate
balitewiczp Fri, 09/05/2008 - 13:33
Yes, I will try that. thankx for the sanity check. Never thought about it in terms of pattern matching for outbound to the qsig, only to the pstn pri. thx again.
