snmpv3 write
Answered Question
Sep 5th, 2008
  • Bronze, 100 points or more
When i'm trying to config snmpv3 to a devices, i didn't see write or read privileges like snmpv2c?
Does snmpv3 read only privilege?
Thanks in advance
Abd Alqader
Correct Answer by Joe Clarke about 8 years 6 months ago
You can assign a write view to an SNMPv3 group. For example:
snmp-server group v3group v3 auth write v1default
This will allow any user in this group to write all typical read-write or read-create objects.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 09/05/2008 - 14:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
a.hajhamad Fri, 09/05/2008 - 14:18
Thanks.
I got it.
I need to add write to the default view (v1default).
I tried before another new view name and i didn't get write privileges.
Thanks again
Joe Clarke Fri, 09/05/2008 - 14:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can create your own view if you want to limit write access to only certain objects. However, you must define that view name before it will work.
