09-05-2008 03:11 PM - edited 03-15-2019 01:05 PM
This user (only one) can't receive calls from outside of my company. Callers get busy tone after dialing his number. But he is able to dial out and recieve calls from internal.
Here is output of "Debug isdn q931"
Sep 5 14:17:44.370 PST: ISDN Se1/0:23 Q931: RX <- CONNECT pd = 8 callref = 0xFA46
Sep 5 14:17:44.374 PST: ISDN Se1/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x7A46
Sep 5 14:17:47.470 PST: ISDN Se1/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Sep 5 14:17:47.470 PST: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x1, Called num 5597451
Sep 5 14:17:47.470 PST: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x7A48
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98396
Exclusive, Channel 22
Calling Party Number i = 0x0181, '5065597720'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '5597451'
Sep 5 14:17:47.706 PST: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xFA48
Sep 5 14:17:48.130 PST: ISDN Se1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0xFA48
Progress Ind i = 0x8288 - In-band info or appropriate now available
Called number 5597451 is having incoming calls problem.
Any suggestion will be appreciated!
09-05-2008 07:18 PM
Make sure CSS for GW can reach the partition where this DN is located.
Debug is showing called party number
5597451
But should be an incoming call
RX
If you can provide another debug will be fun
Thanks!
09-06-2008 07:10 AM
Thanks a lot for reply.
The one thing confused me is:
how to tell this output is for incoming call or for outgoing call? Because I dialed 95597451 from one of the internal number '5065597720' while testing.
09-06-2008 07:30 AM
Check your route plan report for any unassigned directory numbers matching your users extension....can you dial the number from the gateway if H.323 ?
09-06-2008 09:25 AM
We have H323 GW. Sorry I'm new to VOIP world. could you pls give me detailed info about how to dial the number from the gateway?
Thanks.
09-07-2008 08:30 AM
I'll do that. Thanks.
09-06-2008 11:03 AM
Call from your cellphone to that number and enable debug also CCM SDI and SDL traces.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Include calling, called number and timestamps
09-07-2008 08:29 AM
Thanks for you info.
