09-05-2008 05:09 PM - edited 03-15-2019 01:05 PM
Hello Netpro
I have to change a 2600 GW with E1 module VWIC-1MFT-E1 with MGCP on a platform 4.0(2) a module E1 VWIC2-2MFT-T1/E1 GW 2851.
In making this change, somehow will impact the functioning of the CCM 4.0(2)?
I've been doing testing and 2851 were register in the CCM 4.0 (2) but I have doubts about the routing of calls. Moreover although the router tells me that this Register in the CCM shows me as Not Register.
Greetings
09-05-2008 05:21 PM
with MGCP if u wanna route a call through the E1 u have to chose the E1 in the route pattren it self as the gateway
u have to define the gtaeway and its modules again as well
then se,ct the new module as the gateway for calls need to exitthrough it
hope this helpful
09-06-2008 07:42 AM
Why in the router the command "show ccm-manager" tells me that this Register in the CCM but at the CCM does not appear as Not Register?
Greetings
09-07-2008 06:42 AM
sh ccm on the router only reflects the keepalive exchange is being done, not that the GW is really working
and yes, since you're changing the module you need to modify the config in CUCM to match the new NM you have in there, the MGCP packets are SPECIFIC TO MODELS so if you still have the same old config on CUCM when the new module is in, it's expected to not register until the info matches on both sides
java
if this helps, please rate
