ACS 4.2 with patch 4 >> Services restart
Sep 6th, 2008
I have installed ACS 4.2 with patch 4
Scertain period after authentication failed. Giving internal error. I need to restart all the services. What could be proble and pl help me in resolving this issue. I am running short of time.
Premdeep Banga Sat, 09/06/2008 - 09:31
  • Gold, 750 points or more
Internal Error is very generic in error. I hope that you had your Logging set to Full, if not then you wont be able to see the exact reason in the debug logs.
You might want to check,
\CSAuth\Logs
And check the debug log when you got the internal error for a particular authentication attempt.
Also, what kind of authentication was failing ? Was it PEAP/EAP-FAST with inner method as MSCHAP machine authentication, then it could be something related to,
CSCsq96755 : ACS needs manual restart to recover machine authentication
Then go for Patch 5 for ACSv4.2
Prem
Please rate if it helps!
amitmarathe Mon, 09/08/2008 - 05:24
Thanks for your responce. As this is installed on win2k3 server update patches are not available for server centric ACS. Its available only for acs hardened cisco devices. I opened a tac case for the same. The strange thing is that it very well working with Radious protocol. Its only giving me problem with TACACS+. I suggested the same to TAC regarding the patch update.
I have one question.
How I can configured network devices for single-connect ?
Thanks for your support.
