09-06-2008 02:06 AM - edited 03-15-2019 01:05 PM
I'm trying to set up a destination pattern that allows a caller to dial a # (octothorpe) before a number. We have a service from British telecom in the UK that requires us to dial #21# to access this external number
I have tried the following
dial-peer voice 55 pots
destination-pattern 9#21#T
However, after picking up the outside line (using 9) the rest of the number is not dialled. I think this is because the Call Manager strips out all the numbers after the #, as the # is normally used to signify that the preceding number is the last one in the sequence
I see that the question has been asked before (back in May) but I couldnt see that there was a successful answer)
Any help would be great
Many thanks
Paul
Solved! Go to Solution.
09-06-2008 08:47 AM
ok make more simple
i have just tested this one
voice translation-rule 2
rule 1 /^921/ /9#21#/
voice translation-profile p21
translate called 2
the verification:
Router#test voice translation-rule 2 921
Matched with rule 1
Original number: 921 Translated number: 9#21#
good luck
and let me know
09-06-2008 03:52 AM
hi Paul
the solusion to ur problem as follow
lets say in call manager u have a route-pattren with pattren 9.XXXXXX
and u have discard pre dot digits
now lets say u cal from call manger 9123456
the call manager will discard the 9 and send to the GATEWAY 123456 only
on the gateway we gonna make a translation-rule that match any dialed number and prepend a #21# so the numbet will send to the telco as #21#123456
as the following
voice translation-rule 1
rule 1 /\.*/ /#21#\1/
translate called 1
destination-pattern 1T
translation-profile outgoing p21
port [portnumber]
forward-digits all
this is the test for the above translation
Router#test voice translation-rule 1 123456
Matched with rule 1
Original number: 123456 Translated number: #21#123456
look the called number was 123456 translated to #21#123456
u can make it more spisific like if the cal lgoing to the teleco start with a number like in our example 1
u cam make it like
rule 1 /\1*/ /#21#\1/
by the way i would also sugist u dont use the T in the destination pattren as it will wait unitle the interdigit time oute hic is 15 second make more spisific for exampe if u have the number to the telecom like in our example six digits and start with 1 do it like
destination-pattern 1....
port [portnumber]
forward-digits all
good luck
if helpful Rate
09-06-2008 07:32 AM
Thanks for the quick reply
Not sure I described the problem correctly.
#21# is the number I wish to dial in its entirety. It is a number we need to call to access a specific service from our telco. The only other times we need to use the # sign, is also to access a telco service, using #67# and #61#
As we need to dial 9 for an outside line, these are the 3 times we use the # sign
9#21#
9#67#
9#61#
ALL other numbers we dial start with a 9 but DO NOT require the # sign
eg
90178454321
90178498765
Hope that explains a bit better
Many thanks
Paul
09-06-2008 07:36 AM
so u send for example #21# to the teleco and then u get dial-ton then u enter a normal number is that right ?
and the 9 should be send to the teleco as well
like 9#21# or only #21# ?
09-06-2008 07:46 AM
from my understanding what u could try
instead of tell users to dial for example 9#21# tell them to dial 921 and creat a route-pattren for this number and send it to ur h323 gate in the gateway do similer translation-rule to one i sent u with simple change for example
rule 1 /921\/ /9#21#\1/
translate called 1
destination-pattern 921
port [portnumber]
forward-digits all
based on this config
the ip phone will dial 921
this will match a route-pattren in callmanager with 921 and will send the whole number to the h323 gateway with 921
once this number arrive to the gateway it will match dial-peer 55 and becase it match a transaltion pattren on that dial-peer as well applied for outgoing called number so the dialed number 921 will be send to ur teleco as 9#21#
if u dont want the 9 to be sent to the telco just remove it fron the translation like:
rule 1 /921\/ /#21#\1/
then the teleco will get only #21# while the internal user dialed only 921
but i am not sure if that what u look for anyway if not just let me know what is the number shoud reach ur gateway and what number should be sent to the teleco
i mean as i mention only 9#21# so the above config apply to this idea if not just let me know exaclty
and good luck :)
09-06-2008 08:04 AM
Many thanks....I think this is the closest
translate called 1
port [portnumber]
forward-digits all
....so the dialed number 921 will be send to ur teleco as 9#21#
What happens is thet the user dials 9#21# and the telco answers with the voice message....
"dial the number to which you want your calls diverted, followed by #"
at that point, the user types in, for example...
0178454321#
..and then hangs up. This means that the analogue line from which the user has called from, is automatically diverted by the telco to a different analogue lie...ie 0178454321
I will try the solution you mention above, but we already have a voice translation-rule 1 which works and is...
rule 1 /^\(.*\)/ /9\1/
Should I create your voice-translation as a new rule eg
translate called 2
port [portnumber]
forward-digits all
Many thanks
Paul
09-06-2008 08:09 AM
yes u can rul 2 or any number
by the way
it gonna work but just make sure the 9 should be send or not and either way i sent u the rule for both ways
good luck
if helpful Rate
09-06-2008 08:28 AM
Hi again
I tried it but get the following error
UC520(config)#voice translation-rule 2
UC520(cfg-translation-rule)#rule 2 /921\/ /9#21#\1/
% trailing \ ^
% Invalid input detected at '^' marker.
09-06-2008 08:47 AM
ok make more simple
translate called 2
the verification:
Matched with rule 1
good luck
and let me know
09-06-2008 08:53 AM
Excellent - many thanks, worked a treat
09-06-2008 08:59 AM
cool i am glad it working
