ASA License
Sep 6th, 2008
I have two ASA 5520 both having same IOS and hardware configuration.Please find the license for both ASA..
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 150
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Disabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 750
WebVPN Peers : 2
This platform has an ASA 5520 VPN Plus license.
Now my qusetion is shall I configure Active/Standby failover by using this two ASA?
Thanks.
Richard Burts Sun, 09/07/2008 - 12:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
somnath
The license information indicates that it supports active/active configuration. So if you wish to configure it in active/standby then that should certainly be supported by the license.
I note that 3DES-AES is disabled. This will not prevent your active/standby configuration, but I would suggest that you might want to get the 3DES-AES activated on the license.
Rick
