suschoud Mon, 09/08/2008 - 07:49
Syslog server could be:
- Kiwi Syslog:
http://www.kiwisyslog.com/
- 30COM Deamon
http://www.ncat.co.uk/Download/
- There is also a Cisco Syslog Server which supports TCP Syslog 514 - pfss512.exe
http://www.cisco.com/cgi-bin/tablebuild.pl/pix?sort=release
Commercial products that creates graphs and analyzes Syslog to generate stats could be:
- FireGen http://www.eventid.net/firegen/
- Try this one FWLOGSUM (Freeware).
http://www.ginini.com/software/fwlogsum/
http://www.ginini.com/software/fwlogsum/converters/
It uses basicly PERL scripts and supports a wide range of Firewalls. You just need to install Perl in your Windows environment.
- Try Sawmill (Eval version)
http://www.sawmill.net/
- EIQ Networks Network Security Analyzer eiqnetworks.com
Hope that gives you some ideas what to try.
Sushil
Naveen kumar Wed, 09/10/2008 - 01:44
Hi Sushil,
Thanks for ur support, currently i dont have perl S/W with me. i will try with sawmill.
Thanks a lot
