Config EoMPLS problem
Sep 6th, 2008
dear all !
I've configred EoMPLS. I've got a problem with it: VC status always down but neighbour is up.
diagram is :
R3--(f1/1)--(f0/0)--R1--(E1/1)--(E1/1)--R2--(f0/0)--(f1/1)--R4
Configuration:
router 1:
mpls label protocol ldp
pseudowire-class abc
encapsulation mpls
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface FastEthernet0/0
ip address 172.16.0.1 255.255.255.0
duplex half
interface Ethernet1/1.10
encapsulation dot1Q 10
xconnect 2.2.2.2 10 pw-class abc
remote circuit id 10
mpls ldp router-id Loopback0 force
Router2:
encapsulation mpls
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 172.16.0.2 255.255.255.0
duplex half
xconnect 1.1.1.1 10 pw-class abc
show command
R1#show mpls l2transport vc 10 detail
Local interface: Et1/1.10 up, line protocol up, Eth VLAN 10 up
Destination address: 2.2.2.2, VC ID: 10, VC status: down
Output interface: unknown, imposed label stack {}
Create time: 00:01:06, last status change time: 00:01:02
Signaling protocol: LDP, peer 2.2.2.2:0 up
MPLS VC labels: local 18, remote 19
Group ID: local 0, remote 0
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, seq error 0, send 389
please give me some advices !
thanks all.
shivlu jain Sun, 09/07/2008 - 22:44
  • Silver, 250 points or more
You are using encapsulaton MPLS, it means your path should be mpls enabled. But from your config I am seeing one mistake the interface e1/1 are using as bakbone interfaces and mpls ip and mplas label protocol should be configured on the interfaces. But in your config these are missing.
regards
shivlu
pocketldq Sun, 09/07/2008 - 23:17
I'm terrible sorry shivlu. the exactly diagram like this:
R3--(f1/1)--(E1/1)--R1--(f0/0)--(f0/0)--R2--(E1/1)--(f1/1)--R4
thanks for your reply.
Giuseppe Larosa Mon, 09/08/2008 - 09:21
  • Hall of Fame,
    Founding Member
Hello Lai,
verify the correct signaling and forwarding for MPLS LSPs
R1: sh mpls forwarding 2.2.2.2
R2: sh mpls forwarding 1.1.1.1
R1:e1/1.10 must connect to the CE router and not to the backbone
R2:e1/1.10 must connect to the CE router and not to the backbone
this can work if there are L2 switches in the middle able to connect different subifs to different vlans.
these are L2 VPN access links not backbone links even if connected back to back.
Hope to help
Giuseppe
