mgcp registration issue
Sep 6th, 2008
  • Gold, 750 points or more
I have a mgcp gateway(2811), which has been in service for over a year. Mgcp registration is flapping between the publisher and subscriber about every 10-15 seconds, which does not give the T1 a chance to come up. I also have 4 fxs ports on the gateway. The PRI is testing ok. With a loopback plug the gateway still flaps. With the PRI disconnected the gateway is stable and it shows the fxs ports registered to the publisher. A debug mgcp packets shows
*Sep 5 15:24:40.071: MGCP Packet received from 10.20.0.11:2427--->
200 720225718
*Sep 5 15:24:40.071: [S] mgcp_msg_ack:6059,Updating (*)=10.20.0.11
*Sep 5 15:24:40.075: *:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU*/DS1-*/*:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-*/*:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/*:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/1:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/2:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/3:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/4:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/5:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/6:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/7:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/8:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/9:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/10:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/11:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/12:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/13:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/14:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/15:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/16:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/17:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/18:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/19:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/20:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/21:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/22:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: S0/SU0/DS1-0/23:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: aaln/S*/SU*/*:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: aaln/S0/SU*/*:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: aaln/S0/SU1/*:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: aaln/S0/SU1/0:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: aaln/S0/SU1/1:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: aaln/S0/SU1/2:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.075: aaln/S0/SU1/3:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
*Sep 5 15:24:40.179: MGCP Packet received from 10.20.0.12:2427--->
200 720225720
RQNT 2038094 AALN/S0/SU1/[email protected]_Commons_2811.Coastline.org MGCP 0.1
X: 2
R: L/hd
Q: process,loop
*Sep 5 15:24:40.183: MGCP Packet sent to 10.20.0.12:2427--->
200 2038094 OK
We have ordered a new vwic card, hoping it is a bad card. Any help would greatly be appreciated!!
gogasca Sat, 09/06/2008 - 11:37
  • Green, 3000 points or more
Did you guys change hostname in router or in CUCM?
could you please send us the sh ccm-manager
Enable debug and bounce mgcp process so we can see whats happening from the beginning
Charles Hill Sat, 09/06/2008 - 12:41
No, we haven't changed the name, but I'll re-verify the name in both locations. If the gateway registers along with the 4 fxs ports with the Publisher, doesn't this indicate that the name has to be correct? I have bounced the mgcp process and attached the output. Sh ccm-manager shows the registration is flapping about every 30 seconds. IF you find a resolution, you will be my hero! Thanks in advance for any assistance.
whanson Sat, 09/06/2008 - 15:07
can you send a copy of the config and a show ver
whanson Sun, 09/07/2008 - 16:23
add this to mgcp section
mgcp bind control source-interface FastEthernet0/0.200
mgcp bind media source-interface FastEthernet0/0.200
also, are you absolutly sure that CM definiton for the gateway still points to the correct slots on your router for the PRIs? I assume they are both active.
Charles Hill Sun, 09/07/2008 - 17:03
Thank you for your response. I added mgcp bind control source-internal FastEthernet0/0.200 and the media command, unfortunately the registration is still flapping. I disabled mgcp and re enabled mgcp after I entered the commands.
whanson Sun, 09/07/2008 - 17:39
reset from CM
if this is prior to v5 of CM look at the event viewer. What are you seeing relative to the registration. If after v5 then use remote monitor to get the same info.
Also, if you start buffered logging on the router are you seeing anything relative to the pri? From what you are saying, if you shut down the controllers the problem goes away. Do you have to disable both for the registration to stop flapping?
Lastly, can you access (https) the gateway from the publisher and subscriber to make sure there isn't some kind of replication problem. Does the definition look the same?
gogasca Sun, 09/07/2008 - 17:55
Hi Charles,
Sorry for not updating before,
Since with loopback is still flapping and at the beginning it manages to register I believe problem may reside in CUCM side due to:
*Sep 6 20:35:08.045: MGCP Packet received from 10.20.0.11:2427--->
AUEP 2033722 S0/SU0/DS1-0/[email protected]_Commons_2811.Coastline.org MGCP 0.1
F: X, A, I
*Sep 6 20:35:08.049: MGCP Packet sent to 10.20.0.11:2427--->
200 2033722
I:
X: 0
L: p:10-20, a:PCMU;PCMA;G.nX64, b:64, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM;LOCAL, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:10-220, a:G.729;G.729a;G.729b, b:8, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM;LOCAL, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:10-110, a:G.726-16;G.728, b:16, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM;LOCAL, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:10-70, a:G.726-24, b:24, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM;LOCAL, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:10-50, a:G.726-32, b:32, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM;LOCAL, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:30-270, a:G.723.1-H;G.723;G.723.1a-H, b:6, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM;LOCAL, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:30-330, a:G.723.1-L;G.723.1a-L, b:5, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM;LOCAL, v:T;G;D;L;H;R;ATM;SST;PRE
M: sendonly, recvonly, sendrecv, inactive, loopback, conttest, data, netwloop, netwtest
CUCM and GW ack endpoint status.
then CUCM sends:
*Sep 6 20:35:20.161: S0/SU0/DS1-0/1:NO-MATCH, 10.20.0.12:2427, 10.20.0.11:2427
1.Could you please try firs disabling voice port:
S0/SU0/DS1-1 since were are still trying to resgiter it, and unconfigure it in CUCM
2. CUCM version and make sure replication is correct since we have seen this before when replication is not working.
Charles Hill Mon, 09/08/2008 - 15:26
Thanks for the input. It is greatly appreciated. The problem is resolved. Last week someone added qos to int s0/3/0, which I assume was dropping the keepalives. I did not realize the qos was a recent change. :( We removed the qos and everything is fine!
