LMS 3.0 proccesses crashing after install
Sep 6th, 2008
I did a new install on a an HP blade. For the first hour everything runs fine but then for no reason that I can find all the processes start shutting down. According to the proceesses page the admin shut them down. When I look at the Windows server event logs I am getting slammed with constsnt INCHARGE errors. Has anyone seen this before? Is is possible that the HP management software on the server blade is causing the crashes? Any help would be appreciated.
Joe Clarke Sat, 09/06/2008 - 13:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This sounds like a known bug in DFM 3.0. Please make sure you are running LMS 3.0.1 with DFM 3.0.3. The bug will be fixed which will prevent the server's TCP buffer space from being exhausted.
