Paging in CME (SCCP)
Sep 6th, 2008
I configured my CME to have paging feature.But i couldnt make it function. All the speaker phone lights are showing when i dial the paging number, But there is no voice coming out...
I didnt it in the same way as mentioned in the below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmepage.html
Please let me know is there any thing which i need to add along with this
Overall Rating: 3 (1 ratings)
Chris Deren Sat, 09/06/2008 - 13:22
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You need to ensure multicast traffic is enabled and working on your network.
Chris
joelau007 Fri, 11/07/2008 - 22:01
Hi, Did you manage to find the cause of the problem ? I'm also looking at the same problem, phone lights up but no voice. Phones are on the same VLAN so i don't think it's a multicast issue.
Regards.
Chris Deren Sat, 11/08/2008 - 06:11
  • Hall of Fame,
Even if it's on the same VLAN you need to make sure multicast is enabled on your network.
Chris
joelau007 Sat, 11/08/2008 - 16:25
Hi, Just to eliminate the switch from the list of problem areas, I have tested the multicast functions of the switch. I put 2 PCs on the voice VLAN and installed a multicast testing software on them. They talk ok.
Regards.
joelau007 Mon, 11/10/2008 - 06:08
I have fixed it. Turns out to be a multicast problem as the CME is on another VLAN and i didn't expect the paging traffic to originate from the CME IP address. (I was expecting the traffic to be from 1 phone to the other phone, thus on the same VLAN)
