CUCM install on non MCS HP DL380 G5
Sep 6th, 2008
I am looking to buy a HP DL380 G5 for use as a CUCM server (we are currently 4.1.3 soon to upgrade to 6.x). Looking at www.cisco.com/go/swonly the only model supported is the 5140 processor version. The suppliers we use are unable to get that model as it has been discontinued.
Is there another HP DL380 G5 that is supported or does this mean we can not add any more servers to our cluster. MCS servers are not an option for us.
Rob Huffman Mon, 09/08/2008 - 06:04
Hi Stephen,
Sorry about that, I din't realise that this box was the 5140 :( It's more than likely that the newer (more powerful) HP server will be supported as well and the Cisco docs are not quite up to date. I haven't seen an update on these for a few months at least.
I would contact both HP Support and Cisco TAC to verify before purchasing just to be safe.
Hope this helps!
Rob
Chris Deren Mon, 09/08/2008 - 06:47
You always have to be careful about the OEM servers as Cisco may fall behind and the new server spechs will not work on current software levels as you are describing. If you cannot get the exact specs as listed in the document the install will always fail and you have couple of choices: either get the exact server spechs from HP or get the MCS servers from Cisco.
Chris
stephen_harriso... Mon, 09/08/2008 - 07:15
I am working hard on trying to find a server but not having much luck. There was a (one) refurbished server available a few weeks ago but that was all that was available.
