VPN client shortcut
Sep 6th, 2008
I am using Windows Installers MSI to customize the VPN client 5.0.03. Is there a way to include VPN client shorcut and VPN client in the package? I am able to package the VPN client, but I am not able to include the VPN client shortcut (Start, Programs, Cisco Systems, VPN Client).
Thanks.
Debra
sadbulali Thu, 09/11/2008 - 11:24
  • Bronze, 100 points or more
The vpn shortcut Start-> Programs->Cisco Systems->VPN Client will be created automatically when you install the vpn client on your system.If the shortcut is not appearing try unistalling the client and reinstall the same which will solve the issue.
debra-brown Thu, 09/11/2008 - 13:06
Thanks for your response. I uninstalled and reinstalled Cisco VPN client. The VPN client shortcut still does not create automatically. Do you have any other suggestions?
By the way, is there a way to put all the files (VPNclient_msi, oem.mst, *.png, etc.) in one executable file? Thanks.
Debra
