How can i have access the sql device table from CLI, for CCM6.1
Sep 6th, 2008
hello,
last time i have added one device phone and i try to change something i cannot, it said ma duplicate value.
it's any possibility to remove this phone from the CLI.
gogasca Sat, 09/06/2008 - 12:16
  • Green, 3000 points or more
we normally use "run sql" command from CLI, then sql statement
you can run some queries to display the value that is duplicate run sql select * from device etc//...
Which value you are trying to change\modify?
could you plese send us an screenshot?
Jaime Valencia Sun, 09/07/2008 - 06:46
  • Cisco Employee,
  • Hall of Fame,
    2011
it is possible but you require to get rid of all the references from the phone in several tables depending on what it has configured, if you have services and other stuff you would require to modify about 5 tables for 1 phone.
it would be easier if you mention what's the exact issue you're facing and the version for us to provide help, it might be a simple bug or there could be another workaround
java
if this helps, please rate
