CSM VIP stops responding to pings
Sep 7th, 2008
I have a simple config with a virtual server accepting all ports and pointing to a serverfarm with one server. I can ping the VIP fine and then it stops responding for no reason that I can find. I rebooted the CSMs and upgraded code from 4.2(3a) to 4.3(1) with no change in behaviour. Any ideas??
vserver SVR-1
virtual 10.252.44.4 any
serverfarm FARM-1
persistent rebalance
inservice
serverfarm FARM-1
nat server
nat client NAT-VLAN59
real 10.135.133.15
inservice
Thank you..
chris.pomeroy Sun, 09/07/2008 - 16:28
Have you checked to see if the real is failed out? If the real stops responding for any reason it will go into a arp_failed state. Try doing a sho mod csm vserver to see if you vip is inservice.
carlsond Mon, 09/08/2008 - 06:05
The servers in the farm are up. We are not using a keepalive on them. The service is working reliably and one VIP averages 1200+ connections so if there were other issues I'm pretty sure we would here about it.
Thanks...
