09-07-2008 04:57 AM
I'm currently testing LMS 3.1 in a Solaris zone.
Problems started when I enabled SSL mode.
Even after a complete uninstall/reinstall, jrm always dies (see attached sanitized logfiles).
The log messages do not make sense for me, so what's the problem here?
Solved! Go to Solution.
09-07-2008 07:29 AM
This is what I thought. Change the ServiceName to the actual short hostname of the zone (i.e. this appears to be simply "lms"). Restart dmgtd.
09-07-2008 07:14 AM
Please post your /opt/CSCOpx/lib/classpath/jrmuser.properties file.
09-07-2008 07:20 AM
#Configure the username to pass for Jobcli and Lockcli
#Sun Sep 07 13:27:52 CEST 2008
Username=admin
ServiceName=JrmServiceManager_lms.hrz.uni-bielefeld.de
09-07-2008 07:29 AM
09-08-2008 07:37 AM
Yep, now it's working fine, thanks.
Nevertheless this raises another question.
Should I better enter the FQDN during installation and fix this file again, or is it better to use the unqualified hostname and fix the certificate configuration later?
09-08-2008 10:33 AM
It's best if you can use the short hostname as much as possible. The only variable which should hold the FQDN is PX_FQDN which is found in NMSROOT/lib/classpath/md.properties.
09-09-2008 06:16 AM
Thanks again. I'll use the bare hostname on the next installation attempt.
Now I'd like to see this a) documented and b) enforced by the setup script.
