Nat (or what?)
Sep 7th, 2008
Hello all
My boss has asked me to configure a 2600 in a way so that all traffic destined for a server - lets call it /24 located on eth 0/0 - is forwarded to another server - lets call it /24 on eth0 0/1.
Is what i need a static nat ?
what should my config be like?
(assume i call eth 0/0 /24 and eth 0/1 /24)
thank you
simontibbitts Sun, 09/07/2008 - 10:10
Hi Jan.
Try this configuration.
interface Ethernet0/1
ip address
ip nat outside
interface Ethernet0/2
ip nat inside
ip policy route-map DIVERT_10.0.1.10
ip nat pool IP_10.0.2.10 netmask
ip nat inside destination list IP_10.1.0.10 pool IP_10.0.2.10
ip access-list extended IP_10.1.0.10
permit ip any host
route-map DIVERT_10.0.1.10 permit 10
match ip address IP_10.1.0.10
set interface Ethernet0/1
The reason I have added policy routing is because the routing decision is made before NAT on an inside to outside translation. Without the policy routing all the traffic will still be destined to E0/0 which isn't the outside interface so won't get NATTED. The configuration above should work, you need to configure 'ip nat inside' and 'ip policy route-map DIVERT_10.0.1.10' on ALL your incoming interfaces.
towli Sun, 09/07/2008 - 10:19
Wau ! - thanx a bunch I would NEVER have figured this one out myself. I will let you know if it works as intended.
