zone-based fireall class-map access-list with 'log' not supported...
Sep 7th, 2008
I'm using IOS (c3845-advipservicesk9-mz.124-15.T3) zone-based firewall on a 3845 router and when I enable logging on an extended access list (permit ip any any log) that I have applied to a class-map, I get the following message:
"class-map my_cl_map : access-list with 'log' not supported, pls remove 'log' from access-list otherwise class-map my_cl_map will not work properly"
Any ideas what this means? If I apply permit any any log again, it will take it. But what are the consequences?
Relevant config:
class-map type inspect match-all my_cl_map
match class-map protocols
match access-group name my_acl
ip access-list extended my_acl
permit icmp any any
permit tcp host 192.168.1.1 any eq 1022
permit tcp host 192.168.1.1 any eq 513
permit tcp host 192.168.1.1 any eq 514
y.demissie Mon, 09/08/2008 - 04:56
I'm trying to capture what else is needed by doing "permit ip any any log". However, that's besides the point. Do you know why "log" in access lists applied to class-maps not allowed?
y.demissie Mon, 09/08/2008 - 08:51
In other words, you have no idea what ""class-map my_cl_map : access-list with 'log' not supported, pls remove 'log' from access-list otherwise class-map my_cl_map will not work properly" means.
In other words you don't understand english too well.
"the acl is there to identify traffic for the policy, nothing else. "
Identifying traffic with an ACL using a log option isn't going to identify the traffic correctly. If you want to see what's dropped, use the "drop log" in the policy-map for class class-default.
