09-07-2008 12:06 PM - edited 03-06-2019 01:13 AM
hi everbody!
i just want to know when we use " show controllers int e0" command, we get
Rx ring with 16 entries.
My question is does 16 means total number of buffers from both standard public buffer poool and private system buffer pool?
thanks a lot!
Solved! Go to Solution.
09-08-2008 03:04 AM
Hello Sarah,
I may be wrong but I don't think they are the same.
RX ring is more interface related.
see for the system buffers
http://www.cisco.com/en/US/products/hw/modules/ps2643/products_tech_note09186a0080093fc5.shtml#pools
see this example of sh controller ethernet
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s2.html#wp1016433
here the 32 entries are all 1524 bytes each
Hope to help
Giuseppe
09-08-2008 03:04 AM
Hello Sarah,
Hope to help
Giuseppe
09-08-2008 10:17 AM
thanks a lot Giuseppe!
