09-07-2008 01:02 PM - edited 03-06-2019 01:13 AM
hi,
i'm using a C2960 in one of our LAN office. is confreg 0xF ok? i know 0x2102 is the good confreg setup. will this affect the switch boot sequence or if ever restarts and stuck in Rommon?
vimix4#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)SEE2, RELE
ASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 04:33 by yenanh
Image text-base: 0x00003000, data-base: 0x00AA2F34
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWA
RE (fc1)
vimix4 uptime is 2 weeks, 4 days, 16 hours, 46 minutes
System restarted at 21:10:12 PDT Tue Aug 19 2008
System image file is "flash:c2960-lanbase-mz.122-25.SEE2/c2960-lanbase-mz.122-25
.SEE2.bin"
cisco WS-C2960-48TC-L (PowerPC405) processor (revision B0) with 61440K/4088K byt
es of memory.
Processor board ID FOC1050ZB7P
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1A:A1:56:5F:80
Motherboard assembly number : 73-9835-07
Power supply part number : 341-0097-02
Motherboard serial number : FOC10500UFM
Power supply serial number : DCA1045816B
Model revision number : B0
Motherboard revision number : C0
Model number : WS-C2960-48TC-L
System serial number : FOC1050ZB7P
Top Assembly Part Number : 800-26672-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COM3F00BRA
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 50 WS-C2960-48TC-L 12.2(25)SEE2 C2960-LANBASE-M
Configuration register is 0xF
Solved! Go to Solution.
09-07-2008 04:38 PM
John,
The current configuration register is the correct one that you want. Since you need to hold down the mode button to initiate the switch into rommon instead of the configuration register like most routers. 0xF is the default and recommended configuration register for the 2960 switch and is not changeable.
HTH,
Mark
09-07-2008 04:36 PM
deleted
09-07-2008 04:45 PM
The link you provided is for routers not the lower end switching platform. Though visible in the show version output, the configuration register information is not supported on the switch.
09-07-2008 04:38 PM
John,
HTH,
Mark
09-13-2008 05:37 PM
cool! thnx!
