Adsl PVI/CVI limitation
Answered Question
Sep 7th, 2008
Hi,,
I'm trying to setup cisco 1801 router with adsl port to internet, I had contacted my ISP about the pvi/cvi setting and i get 100/100.
when i tried to implement the PVC 100/100 it is only accepts 0-31 for the PVI is there any way to get over theis issue, My ios ver is 12.4(15)T6.
Regards fo all
Correct Answer by Giuseppe Larosa about 8 years 7 months ago
Hello Osama,
try the following
atm vc-per-vp 256
to change the number of VCI per VP and see if it changes the allowed range of VPI
Hope to help
Giuseppe
Overall Rating: 4 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 09/08/2008 - 02:52
  • Hall of Fame,
    Founding Member
Hello Osama,
try the following
atm vc-per-vp 256
Hope to help
Giuseppe
