EBGP Backup Route Not working Properly
Sep 7th, 2008
I have a Route with 2 serial links connected to the same ISP. One is a T3 and one is a T1. The T3 is the Primary Link and the T1 is the Secondary Link. I have floating static route configured as well as MED to set a higher metric for the Secondary T1 backup Link. I want the Secondary link to become active when ever the primary one is not available but, whe I bring down the Primary link both links go down. Please look at my config below to tell me what I have done wrong. Thanks.
hostname ISP
memory-size iomem 10
ip subnet-zero
no ip domain-lookup
ip cef
call rsvp-sync
interface FastEthernet0/0
ip address 200.200.100.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 200.200.1.1 255.255.255.0
no fair-queue
serial restart-delay 0
clockrate 56000
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
interface Serial0/1
ip address 200.200.2.1 255.255.255.0
clockrate 56000
router bgp 100
no synchronization
bgp log-neighbor-changes
network 200.200.1.0
network 200.200.2.0
network 200.200.100.0
neighbor 200.200.1.2 remote-as 200
neighbor 200.200.2.2 remote-as 200
no auto-summary
ip classless
ip http server
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
login
end
hostname SanJose1
ip subnet-zero
no ip domain-lookup
call rsvp-sync
cns event-service server
ip address 192.168.1.33 255.255.255.224
duplex auto
speed auto
interface Serial0/0
ip address 200.200.1.2 255.255.255.0
no ip mroute-cache
no fair-queue
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
interface Serial0/1
ip address 200.200.2.2 255.255.255.0
router ospf 1
log-adjacency-changes
redistribute bgp 200 subnets
network 192.168.1.32 0.0.0.31 area 0
network 200.200.1.0 0.0.0.255 area 0
network 200.200.2.0 0.0.0.255 area 0
router bgp 200
no synchronization
redistribute ospf 1
neighbor 200.200.1.1 remote-as 100
neighbor 200.200.2.1 remote-as 100
neighbor 200.200.2.1 route-map med_test out
ip classless
ip route 0.0.0.0 0.0.0.0 200.200.1.1
ip route 0.0.0.0 0.0.0.0 200.200.2.1 2
no ip http server
access-list 1 permit 200.200.100.0 0.0.0.255
route-map med_test permit 10
match ip address 1
set metric 200
line con 0
line aux 0
line vty 0 4
login
end
Richard Burts Sun, 09/07/2008 - 19:19
Charlie
There are some things in your description that do not match up with the configs that you have posted. For example your description talks about a T3 and a T1. But the config that you post for ISP has 2 serial interfaces and both have this:
clockrate 56000
and those interfaces are obviously directly connected to your router (based on the IP addressing). So where is the T3 and the T1?
But the biggest problem is that you have 1 (and only 1) router in AS100 and 1 (and only 1) router in AS200. You are attempting to act as if there are 2 BGP neighbor relationships but there are not. There is a single BGP neighbor relationship (and having 2 neighbor statements will not change this).
My suggestion is that if you have these 2 routers and have 2 serial links and want some redundancy that you do these steps:
- configure loopback interfaces on each router.
- change the BGP config to peer to the loopback interface of the other router.
- configure the bgp multihop to facilitate peering to a not directly connected interface.
- configure a static route and a floating static route on each router to the other routers loopback interface (not a static default route).
- if you want the ISP router to advertise a default route (and if it does not have a default route in its BGP table already) then configure default-information-originate on the ISP router for your router.
That should get you what you want.
Rick
Giuseppe Larosa Mon, 09/08/2008 - 00:14
Charlie,
some notes:
You can use two eBGP sessions on physical interfaces between two routers.
However, the router acting as the customer router should advertise some IP subnets it is owning.
There is no use to try to advertise prefix 200.200.100/24 it is a connected subnet of router isp:
duplex auto
speed auto
and isp it is advertising it:
router bgp 100
so the second eBGP session is useless it is trying to advertise a prefix with MED 200 that has been received by the neighbor !
the neighbor will not accept a prefix containing its own AS number (eBGP loop prevention rule).
Try to use a prefix on customer router Sanjose1 if you miss a free physical interface use a loopback:
int loop 100
ip address 200.200.150.0 255.255.255.0
advertise this in router bgp 200
router bgp 200
network 200.200.150.0
modify the route-map accordingly:
access-list 15 permit 200.200.150.0 0.0.0.255
no match ip address 1
match ip address 15
set metric 200
this time on router ISP a sh ip bgp 200.200.150.0 should show two paths:
now when you shut the primary link the secondary should be usable and used
Hope to help
Giuseppe
