S2S VPN using AES-256
Sep 7th, 2008
  • Blue, 1500 points or more
Just curious if anyone encountered a problem using AES-256 Encryption.
This is the setup.
D_Local_IP<NAT_IN><FW><NAT_OUT>D_Global_IP|S_Global_IP2<NAT_OUT><TCP_Port_Trans><RTR><NAT_IN><IPSec/AES-256><RTR><S_Global_IP1><NAT_OUT><FW><NAT_IN><LB>S_Proxy<FW>S_Local_IP
I was performing tech refresh of the two routers. Between the two routers are P2P Leased Circuit.
IBM MQ Series Server in S_local_IP and D_Local_IP
Both server able to telnet its remote counterpart application port, but not able to establish channel connection in the same port.
I did check the crypto status all seems to work well.
After removing the IPSec from the Serial Interface, all works fine.
I change the encryption from AES-256 to 3DES and re-apply IPSec in the Serial Interface, all works fine.
