Master/Slave Server is not reachable
m.sobolev
We have standalone server install, but then I go to System->object finder and try to search something: i got the following error:
"Master/Slave Server is not reachable"
Joe Clarke
This typically indicates a problem with the System Identity User. Go to Common Services > Server > Security > System Identity Setup. Re-enter the username and password, and make sure the username points to an account with full access to all LMS applications and tasks.
Joe Clarke
Thanks! It works :)
Thanks man
it worked i had the same issue and i applied the same and it worked
