Accessing IPCC Express (Spanlink) LDAP Directory?
Sep 7th, 2008
Has anyone managed to access the LDAP directory in IPCC Express? I am trying to access the global phone book which is apparently stored in the local LDAP directory, but I can only use read only credentials which don't help. There is an "LDAP Pwd" value under HKLM\SOFTWARE\Spanlink\CAD\Site Setup, but I think it must be encrypted.
Any ideas, or has anyone else found a clever way to manipulate the Global Phone Book?
Overall Rating: 4 (2 ratings)
abcronin Mon, 02/02/2009 - 14:36
Hi there
The phone book values are stored in LDAP, along with a host of additional sensitive information. The LDAP is not exposed for modification.
Cisco are working on a bulk import tool however will not be available until mid 2009.
Please rate helpful posts.
nathanreynolds Thu, 04/09/2009 - 06:20
Hello. I am trying to accomplish this same task of importing several hundred entries into the global phone book. Any luck with this? Thanks!
habgooda Thu, 04/09/2009 - 14:40
I've been told the old functionality for bulk import via CSV will return in around 7.0.2 of UCCX, but otherwise there is no way to do it.
abcronin Sun, 04/12/2009 - 18:15
I have found a way to import into the agent phone book using a tool, this is done on the server (IPCCX) and you use agentname.csv files to import for each agent (agentname = username in ccm).
I have tested it with 50 entrys and it works ok.
Let me know if you want more info.
nathanreynolds Mon, 04/13/2009 - 05:32
Hi Andy,
Have you gotten this to work for the global, administratively created phone books though? Does in work in the newer versions of UCCx(5.x, 7.x, etc)? Thanks!
abcronin Mon, 04/13/2009 - 12:01
Hi Nathan
No cannot get this to work on global phonebooks, only employee (agent) using the EmployeePhoneBookUploader exe.
The version I have is 5.0, but should work on 7.0.
nathanreynolds Thu, 04/16/2009 - 12:53
Thank you for taking the time to explain. Any ideas how to access this LDAP directory in read only mode? It would be nice to at least export this data into a more readable format. Thank you again. Nathan
abcronin Thu, 06/25/2009 - 18:25
I wish there was a way...but alas its protected even for read only. Cisco have confirmed that 7.0(2) will have the bulk import and 8.0 will have Enhanced Phone Book Search.....what ever that means.
Are you sure it's protected in Express? I deal only with Enterprise, but I can easily see the LDAP for CAD. I'm sure the same principles apply.
I just use a free LDAP browser - I use LDAP Browser\Editor v2.8.2 by Jarek Gawor.
The port is 38983. The Base DN is "o=Spanlink Communications". Use an anonymous connection.
Attached is a screen shot - I'm not looking at the phone book in this, I'm looking at how silent monitoring is configured.
abcronin Sun, 06/28/2009 - 13:10
Hi Geoff
You are correct, its open and I can browse the LDAP and see all the entrys....nice.
Thanks for the suggestion, I just took their word that is was protected....
Now just need to see if there is a way to update or import.
abcronin Sun, 06/28/2009 - 13:59
oops, just realized this is what Andrew was originally posting about. Its readonly access only and requires a password for modifications.
may bad
Anthony Holloway Thu, 03/01/2012 - 07:54
If you are running version 7x or lower, you can just change the password.
Find the file called slapd.conf on the server, and modify it like so:
# Root user password
# Old Password = ?
# rootpw    {SSHA}qTp612HSRZ9HX7ICW95TCAOOnVNacOK6
# New Password = test
rootpw    {SSHA}9DgilxbKtDVpSW86NjCzcnUkuBtzYWx0
Then restart the sldap process on the server so that it reads the conf file again.
Now you can open the LDAP with the password "test".
I hope this helps.  And be careful!
