BGP- Prefix Info
guruprasadr Sun, 09/07/2008 - 22:49
HI Mahesh, [Pls Rate if HELPS]
? - incomplete, * valid, > best
The above Network Prefix is already a VALID Path in the Network.
The outbound traffic from the Router will take the default BGP next-hop for the prefix.
Hope I am informative.
Best Regards,
Guru Prasad R
Thanx for that
So what you mean if the BGP is taking the path tru which the advertisement is coming will show the NEXT_HOP is it???
so if there is multiple paths to the destination then only it wll show the exact NEXT_HOP specifically .
wheather there is multiple best routes to a single destination???
Please clear this as well????
Giuseppe Larosa Sun, 09/07/2008 - 23:50
Hello Mahesh, this advertisement has been locally generated on the router you can see this from:
a) next-hop means the router itself
b) weight 32768 that is the default value for locally generated prefixes.
By the origin ?=incomplete you can understand that this prefix has been imported as the result of a redistribution into BGP.
Do a sh ip route to see the origin of this route, the output will say redistributed into BGP and advertised by BGP (if advertised to any peer)
It can be the result of redistribute connected for example.
When there are multiple paths to a destination you will see one row for each but the prefix is shown in the first row only and all the other rows will list their own BGP next hop, weight ,... , AS path, origin code.
The best path is marked with *> symbols.
Hope to help
