problem telnet terminates connections
Sep 8th, 2008
Hi all,
I have enabled ssh on a router and wanted to have both telnet and ssh for a while. The problem is that when i telnet to the router it shows three times the login prompt username:
and disconnects!
eg. <LOGIN BANNER>
Username:
Username:
Username:
ssh connects correctly though! Even though i disabled SSH it stills cant open a telnet connectivity.
configuration follows:
line vty 0 4
exec-timeout 30 0
login local
password 7 .....
transport inpute telnet ssh
line vty 5 15
exec-timeout 30 0
login local
password 7 .....
NO acls in!
Debugging telnet follows:
Sep 8 11:19:35.276 EET: Telnet4: 1 1 251 1
Sep 8 11:19:35.276 EET: TCP4: Telnet sent WILL ECHO (1)
Sep 8 11:19:35.276 EET: Telnet4: 2 2 251 3
Sep 8 11:19:35.276 EET: TCP4: Telnet sent WILL SUPPRESS-GA (3)
Sep 8 11:19:35.276 EET: Telnet4: 80000 80000 253 24
Sep 8 11:19:35.276 EET: TCP4: Telnet sent DO TTY-TYPE (24)
Sep 8 11:19:35.276 EET: Telnet4: 10000000 10000000 253 31
Sep 8 11:19:35.276 EET: TCP4: Telnet sent DO WINDOW-SIZE (31)
edit: I've noticed that if i close ssh connection i can telnet to the router...but second telnet is not permitted!(even though telnet service is ok) because i see in the show line that the connection opens and closes. SSH ofcourse no problem!
mikebrsnet Mon, 09/08/2008 - 00:47
I think i fixed it!Well i tried to separate the access to the vty lines.
I configured line vty 5 15 for input telnet only
and the rest 0 4 for ssh.
Now it seems to work! even though i cant understand why did open new connections!
