Problem fax with CCME
Sep 8th, 2008
I've got a CCME and I have a problem with fax, sometimes the fax (sent or received) are cut and I cannot read the page.
I have a server fax linked with ATA and the configuration is:
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
no aaa new-model
memory-size iomem 10
clock timezone CET 1
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
network-clock-participate wic 0
network-clock-select 1 BRI0/0/0
dot11 syslog
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
isdn switch-type basic-net3
voice-card 0
no dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
redirect ip2ip
h323
no h225 timeout keepalive
call preserve limit-media-detection
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice translation-rule 1
rule 2 /^32\([0,3,7-9]\)\(.*\)/ /032\1\2/
rule 3 /^33\([0,3-9]\)\(.*\)/ /033\1\2/
rule 4 /^34\([0,3,6-9]\)\(.*\)/ /034\1\2/
rule 6 /^36\([0,3,6,8]\)\(.*\)/ /036\1\2/
rule 8 /^38\([0,3,8,9]\)\(.*\)/ /038\1\2/
rule 9 /^39\([0-3]\)\(.*\)/ /039\1\2/
rule 15 /^\(\)/ /00\1/
voice translation-profile AddZero-Telecom
translate calling 1
archive
log config
hidekeys
ip tcp synwait-time 10
ip tftp source-interface FastEthernet0/0
ip rcmd source-interface FastEthernet0/0
ip address 192.168.35.254 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.35.254
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn map address .* plan isdn type unknown
isdn send-alerting
isdn sending-complete
isdn skipsend-idverify
trunk-group BRI-Mecavit 3
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.35.1
ip http server
no ip http secure-server
snmp-server community public RO
snmp-server ifindex persist
voice-port 0/0/0
translation-profile incoming AddZero-Telecom
disc_pi_off
echo-cancel coverage 48
no vad
compand-type a-law
cptone IT
timeouts interdigit 5
dial-peer voice 1 pots
description Chiamate da Pstn
answer-address 0T
incoming called-number XXX
fax rate disable
direct-inward-dial
port 0/0/0
dial-peer voice 5 pots
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 1
fax rate disable
port 0/0/0
num-exp XXXX 99
telephony-service
load ATA ATA030100SCCP040211A.zup
max-ephones 24
max-dn 48
ip source-address 192.168.35.254 port 2000
timeouts interdigit 3
user-locale IT
network-locale IT
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
call-forward pattern .T
call-forward pattern 0T
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 0T
transfer-pattern 4T
secondary-dialtone 0
directory last-name-first
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 20 dual-line
number 99
label Fax
name Fax
ephone 14
mac-address 001F.CA35.7A79
type ata
button 1:20
Can you help me??
Michael Owuor Mon, 09/08/2008 - 03:51
  • Cisco Employee,
Hi Luca,
Can you confirm that the ATA has these settings:
audiomode = 0x00150015
connectmode = 0x90000400
lbrcodec = 3
And also make sure that the fax machine is not SuperG3 enabled.
Hope this helps.
Michael.
